Do you have to have real debrid to play anything on the Superman build. Nothing I click on works. It always say real debrid
I don’t use builds but use individual addons. Real Debrid is only a little over 3 dollars a month and you will always have good links to click on that work. Free links are far and few between and ones that actually work are even fewer in between. If your build is telling you Real Debrid, get Real Debrid. You will not be disappointed.
Thank you. I have an IPTV that I use for everything else.
Yeah, my Superman build became too much work. So I decided the beer belly build would be less stressful.
I’m finding the build to be cumbersome and would like to go back to just using the individual add ons, but I cant figure out how to uninstall the Superman build. Any easy way that wont affect my other add ons?
