Superman Build and Real Debrid
I installed the Superman build (running Kodi 20.2) using the TroyPoint video and when I got to the section where it showed how I could add Real Debrid I ran into some issues. I went to add-ons, premium login then chose Universal Resolver 2, in the video it shows where Real Debrid is the top choice. I did not get that mine shows Premiumize.me. Can anyone tell me what I am doing wrong and how I can go about fixing it…thank you!!
Go to a different universal resolver, if it doesn’t say Real Debrid, it wont work.
Scroll down more and redebrid is there
Same issue but it’s not anywhere on the lists
Don’t have debrid but if you go to sports look for mad titan app.click it download it if asked then you can use the scrubs add on with the non debrid…also it may ask to download asguard add on do it it has a free movie tv section…
It is not listed in any of the Resolvers
