Using The Crew for Kodi I want to set up the option for subtitles but have been unsuccessful. How can I temporarily switch off The Crews (wonderful) skin and display the familiar Kodi GUI …or perhaps you know an easier way to achieve what I’m trying to do. Thank you!
Welcome Faecal, It sounds like your using a build ? Crewnique ? If you go into settings and skin, you should find Estuary and click it. I hope this helps
In the Crew (or any Addon) when you are playing a TV Show or Movie from the Menu at the bottom choose the Subtitles Icon (It will be the 3rd from the left). Open it up choose the language you want then “enable Subtitles”
Throttlejockey
Superb. Heart felt appreciation
