Struggling to get my EPG to work
I wouldn’t even mind paying for a service if it worked
Too late i’ve cleared it a few times
This one is free with tons of content and well maintained. Lots to read though. @StreamOnABudget | Canada | #FreeTV Info: Free2View TV -- Free and Public TV without a subscription is here!
I sent you a working epg url. I also sent a link to a topic page that has tons of m3u playlists and epg urls, and suggested 2 to start you off. I posted those 2 m3u and epg codes below. I know for a FACT these are working because I am watching them now as I type this and the channels play and the epg is populated!
Make sure you have enabled your m3u playlists and that you have enabled and assigned your epgs to those playlists!
If that doesn’t work then you have a broken app!
These FREE & LEGAL m3u and epgs I know work for a fact!
M3U PLAYLISTS
https://cutt.ly/F2V_Master
https://cutt.ly/DSr95Combined
EPG URLS
https://cutt.ly/DSr95Combinedepg
https://github.com/bitsbb01/m3u8_creator/raw/main/epg/epg_ripper_ALL_SOURCES1.xml.gz
COPY & PASTE these codes in the proper places when adding to your Tivimate Player. Then go to your playlists section and select each playlist and assign your epgs to each playlist and make sure they are enabled!
Once installed and assigned and enabled. Then give the epg several minutes to populate the epg guides to your channels. If necessary, you may have to go into Channels Settings and manually assign the tv guide listing to specific channels.
I have these exact 2 mu and epgs on 3 different devices and they all work!
Recently, most of my UK EPG listing for all Sky Sports channels and many others, including BBC & ITV, have disappeared. My iptv provider tells me this is not anything to do with them, and is the fault of the developers of the IPTV Panel they use, and so most IPTV providers will have the same issue. Can anyone let me know if I’m being given the runaround, or if this issue is true.
You are being handed a line. I have no issue with my EPG or Sky channels info.
Can anyone explain how to resolve when assigning a channel to epg. I am finding as example bravo has no information for the epg. I select assign epg for the channel . Then i select search and type bravo.
Most times it will not show all
my epg that I have added. It will show only from one supplier sometimes 2 but never all the epg that I have added.
I have a total of 4 epg for populating but assigning epg will only show maybe 2 of them or only one choice .
Any ideas what I am missing?
Thanks powerfader. Was going to find a way to upload an M3U file that has all free channels. Your links do the same.
The OP may be just running into learning curve difficulties. Or it could be his internet blocking certain activity.
The only problem I have with my EPG is I can’t get it to populate more than 24 hrs. No big deal but strange. Talked with my provider, looking in to it. I’ve noticed some UK stations not recording at all, but others do well. I think this is a glitch with the UK stations. Not sure if any provider can promise you 100% service. That would be nice though
