I downloaded it as a lark but it doesn’t pull up anything and when it does it has an RD error. I’d still use Stremio or Syncler because that is what I’m use to. I don’t really see a diference or improvement to what I already have so not sure I would keep it. I did sign up with my Google acct which some said not to, but I can always delete and start over. I didn’t use the RD API code and wondered if this might be the problem, I just used the code from RD
Oh I have multiple google accounts and create new ones as needed. So I created a new account as per Troy’s suggestion. I do this on my Pixel Tablet. I never do this stuff on my phone.
Completed all steps, when I try to watch ANY show or movie I get this error, (on Formuler mini)
If I choose a different source I still get the same error???
More Info!!! I just loaded it onto my Buzztv x5 exact same settings as on The Formuler Mini, and the X5 worked perfect first try, …. All thoughts on the Formuler and getting it to work would be appreciated, thanks all. Should this be its own topic?
Can’t install 1.0.49 on my android box - “problem parsing the package” error message. Same error message when trying to download Strmr from Troypoint Tool Box - no problem downloading other apps, however. Any ideas? Thanks.
I found that I had to turn off my VPN to get results.
You have to turn them off in Playback in the settings. Same as Stremio
Another update has dropped. Woooo hoooo. Except for now it’s back to turning my sound off. Exiting the app I had to go into force close and clear cache to get my sound back in other apps. Specifically TiVimate.
turn what off??
Since I don’t use a VPN I wouldn’t know. Glad you got it to work
The subs in playback.
Sorry Miki, I thought that was an answer that my question ![]()
Is your VPN on? I wasn’t getting any sources with RD, Tor or Premiumize. Turned off my VPN and then sources started appearing
I know I’m not the sharpest tack in the box when it comes to setting up the apps but at least I was able to get Elementum up and running on Kodi. After about 90 minutes of just getting to the STRMR loaded, Google linked, and TRAKT account, I scrolled thru the rest of your setup article and gave up. Not an easy install for me and I’ll stick with Elementum for movies and series. IPTV will get me all the live events I’ll ever need.
Under display settings should “Show Debrid Library” be turned on or off? I’m using RealDebrid. Thanks
My understanding is there will not be another way to log in. I questioned that in the beginning, and even brought it up again.
I added Trakt to mine and it seems to be working the same as on other apps.
I have RD set up and TB also, but I am getting links, I started with only RD.
Thank you and the OP for this! I having been using Stremio for a good bit now but have had several issues recently. I feel like it’s been a sullen teenager who really doesn’t want to do anything I want it to. STRMR has been the easiest and cleanest thing I’ve set up and that’s including switching from RD to Torbox. Hopefully it will continue working this well down the road. Thanks again!
I’m also seeing a 451 error on all streams and yes I have added the scrapers successfully
