Please don’t merge this with another. Those of us who latched onto STRMR are in need of specific help. I was forced to update my STRMR app to 1.1.33. After doing so I’m still logged into TORBox, but there are now NO scrapers and I can’t find a way to add them. without these, the app is a brick. I see others have posted but their post keeps getting merged without any answers. I’d appreciate the help.
Follow Troy’s tutorial on STRMR installation. In the apps scraper url entry, use
https://torrentio.strem.fun/
And
https://comet.elfhosted.com
@keith2002 , did you uninstall your STRMR, then install the New Version? Did you read the merged threads you mentioned, as there is the solution you seek ….
I read merged threads but couldn’t find the answer. Thanks to the reply above I had it fixed in seconds. Not sure why we can’t just leave a thread like this instead of merging threads and having these answers basically hidden.
Perfect, this is what I needed. Couldn’t find this in the merged thread. Hope they leave this here.
We can’t leave the threads like this as then we would have hundreds of individual threads for one single app or topic and would take up more space and add countless data entries and so on. Site search unfortunately is rarely used and no way to bypass the necessity of reading.
I wanted to ask about a Strmr issue but it keeps redirecting me back to Troys install post. However there is no where to reply. Is it closed?
What issues are you having? if this gets merged feel free to message me, I will gladly try to help
if I can.
I was wondering where I could get the version that includes the “Scraper” option that Troy uses in his video?
Scraper option? The new version I think they may have renamed it to add ons.
They no longer provide scrapers in the new version you need to pick and configure the scrapers you want to use, copy the URL once configured and then you will add them here.
That post has been fixed so I will move this over there now.
Thank you.
I rarely use STRMR any more i moved to Nuvio, I like to try different apps and if I find something I like better I move to it until the next one I like better. But still want to be able to help those wanting to set up STRMR.
So I have gotten the scrapers in like Comet, MediaF etc. However I keep getting a lot of “format not supported”. Not sure what that’s all about
I just updated Strmr to v. 1.1.34. Unfortunately it hasn’t gone smoothly. I followed Troy’s direction to the ‘Add-Ons’ portion. Here is where I am stumped. To add Torrentio or Comet, you need their URL, which I don’t have. Do you? If so, can you please forward them? Thank you.
You have to configure addon to your preferences including adding your Debrid info. After configuring click copy link at the bottom for the url you need. Use this link to find configuration pages.
Also if you are only using Real Debrid they are having some issues today.
i have turned it off. uninstalled and re-installed stremio. re-started firestick. only on one tv does stremio not work properly. server starts to open and then immediately closes. no streams/servers open to play.
Another option is to just copy your scraper configuration directly out of Stremio. If you go to your addons in Stremio, click ‘Share addon’ and then from the pop-up box click ‘copy’, it can save you from having to completely re-configure each scraper.
Some addons have a copy URL button down the bottom after clicking the config gear icon for an addon like Comet, for example. That’s why I do all my configuration on my Pixel Tab as copy paste is so easy.
