Stremio & Unlinked Passwords & PINS?
I just jailbroke my Firestick 4k, 3rd Gen. Used troypoint app w/rapid installer to install Stremio and unlinked. When i tried to use Stremio, it wants a password and when using unlinked, none of the codes work and it asks for pin#. WTF?
Also what happened to all the apps that used to be included in the rapid app installer…eg…CinemaHD Free?
Any words of wisdom for newbie would be appreciated.
Thanks
For stremio you need to register. Then when you have just used an email/password and log in you can add any add-ons that you want.
@sailorboy22
Welcome to the community but please use the search function.
That question has been asked over and over, legal reasons for the removal of questionable apps, however troy gives you options to get with unlinked, please go over the guides.
Thanks for the quick reply. Is Stremio registration free?
Qith?
Thanks for the reply. I’ll familiarize myself with the search function.
@sailorboy22
It was a small typo… you can understand what im trying to convey…
But yes, alot of info can be found that way. Stremio requires a login, use a fake email. But the community addons are great.
Thanks.
I think I’ll uninstall the 2 apps and start again after I go over some of the guides again. Im a slow learner I guess.
@sailorboy22
That’s fine, take your time learn slow. Troy has very good guides to walk you threw it.
Yes reg is free, but once you get it completely installed please only use it with a VPN.
