Stremio has been my favourite app for movies for some years. I set it up in the U.K. and has worked perfectly. I have recently emigrated to the US and have finally got round to using my 4K Max again. I installed the new Cinema app just to try it out and linked it with RD. It worked perfectly. When I tried Stremio the Torrentio RD link showed ‘invalid token’. I could not remember how to integrate RD but despite various searches on Troypoint.com I could not find it - the instructions for installing Stremio did not mention RD at all. Reddit gave the web page I now remember Torrentio.strem.fun which brought up the page on my iPad. I got an RD key and pasted it in but when I clicked install it set the browser could not find the page because the address was invalid.
I haven’t been able to keep up with things during my move but it looks like Torrentio and Stremio no longer allow RD links. Is this true or have I missed something and there is a different way of doing it?
If it has gone it woukd be a pity
Ask @Miki he promotes Stremio all the time and might know.
Well thank you for the referral Jayhawks659, I appreciate your vote of confidence. Although I don’t actually promote it, but like you, with Kodi and your love of it, I help where I can if I can, especially when it comes to quality apps in my streaming arsenal.
Good day @Gumboil. It seems like you followed the proper method. Installing the rather lengthy key, is a royal pain. It does make it easier if you can do it on a computer or device that allows you to copy/paste the code. The following link should be where you install the key. Now be sure you have Stremio installed on the device where you copy/paste the API code, and you are logged in. gl2u.
https://torrentio.strem.fun/configure
Definitely a computer is the best way to do it. Tried other ways but cut and paste is the way to go. Good luck
Thanks Miki - yes I was using copy and paste for the key on my iPad. I will give it a go tomorrow. Do I need to uninstall tge Torrentio addon on my stick before I configure and then reinstall it? I seem to remember some words like that in the original instructions but this 77 year old memory isn’t what it was haha.
Well sir I’m 70 so not to far behind ya. In cases like this I always recommend a complete uninstall, reinstall, log in, then go to the link I provided, fill the form in and click install. As long as your RD Sub is active you should be g2g. Not sure about doing it on a tab I never tried. I actually wrote the API down and manually entered it 1 letter at a time. Got it right the first time. I should have bought a lottery ticket.
It is coming back to me now. I originally did it by getting the form up on my stick browser, getting the key on my iPad and then pasting it to the stick using the fire tv app. You can’t get Stremio on an iPad so trying to use the form on that won’t work as I can’t have Stremio open on it. I will either do the same trick as before or use my Mac.
I may well do a reinstall as you suggest. When I first started on computers as an lowly engineer in the mid 60s ours had a big red button labelled ‘Gen Reset’. I recall it got used a lot!
Many thanks again Miki for your help. My favourite movie app, Stremio, is up and running again.
That’s what I like to hear. Way to go. One more piece of your streaming journey. Have a nice day, and enjoy.
