Stremio. Marking Movies As Watched
Hi
One of the features of Stremio, which i appreciate, is the automatic marking of episodes in TV series as “watched”.
Does anyone know if it is possible to mark movies as watched. Or do members, just remove them from their libraries after watching them?
Or, just leave them in the library and try to remember which ones they have already watched?
Many thanks.
If you saved them to your library they will save your spot and you can resume. Thats it
Yes, I am aware of that feature. I
was looking for a solution to marking them as watched. Thank you.
Found this on the pc app.
@Powerfader . Excellent. Many thanks. Will check it out. And see if it reflects on my android app, after marking movies watched.
Just checked my Mac version and the movies are marked with a tick as watched. But there is no image like the one you showed with a menu to mark it as watched.
@TP-Dracoo Could you please reopen this topic as I mistakenly marked it as solved. Thank you.
I dont understand, if ifs watched just delete from the library… the library also tracks progress.
Many thanks. I will consider deleting those movies I have watched.
