Stremio Login Problem
I’ve installed Stremio on a new ONN device.
I do have a Stremio account.
Opening Stremio, I get the Scan the code or the login link options, but not the manual login option.
Using the scanning option links me to my Facebook account, which does not have my Torrentio & addons for some reason.
When using the login link, it shows that my device is linked on my computer, but the ONN never changes to the home screen.
I’ve used the manual login on several devices installing my addons with no issue until yesterday & today.
I’ve already done all the deleting data, force stop, uninstall-reinstall stuff with no success. And I’ve submitted a help ticket, but haven’t heard back.
So two quesions:
-Is there a way to force the app to the manual sign in option?
-Is there a way to delink the Stremio account from the Facebook account?
I like using Stremio, but it has turned out to be a PITA at times to install.
I’m not sure what you did but when you open stremio you should be prompted with a login… Once you sign in it auto signs you in.
That happened to me on the latest update to 1.5.6 I uninstalled and used Troy’s RAI and installed 1.5.5 Problem solved. I hope someone informs Stremio and gets this resolved. My recommendation is DO NOT UPDATE to 1.5.6
I think Miki hit on the answer.
I didn’t upgrade to 1.5.6 so i had no idea that was a bug, im sorry. Thanks for pointing it out.
Help. I have an account with Stremio and usually I just have to log in when I install it on a new device. Firestick(s) no problems but, this time I am trying to install it on an android T95Z and the only option to log in is with a url and a code. That is fine but, after I have entered the url with the code it as .asks me to login to facebook??? I read Mikki’s old post (2022) about this and he had the same problem when Stremio updated to a new version so he went back to an older version. The version I have right now is 1.6.12. Can anyone help me with this. Where can I find an older version of Stremio to see if I still get the same problem
BTW. I have searched insider and read all the messages on stremio and could not find an answer. Looking forward to any respones. Could it be because this is an Android TV Box? I have tried everything and I do undstand what facebook should have to do with this. Also the email I used for Stremio is not on my facebook account.
I’m on 1.6.12 and don’t have this problem. Have you tried to login to Stremio in a private window? Or maybe try a different browser, maybe there is a stuck cookie or something in cache hanging it up. I see the “Log in with Facebook” button but the email/password is right below it.
I also don’t think it is the Android version causing the problem, I have it on various Android/Google Tv and regular Android boxes.
Hi ScoobyDoo…OMG. Maybe because I was working on this for a couple of hours it messed my head up lol. I read your reply and tried again and I have got it to work. It still came up with the facebook login but below (once I scrolled down a bit) there was an option for entering my stremio email and password. I feel pretty dumb right now but thank you so much for your reply. Next problem I have, I will walk away for a few hours and try again. LOL
Thank you :smiley:
LOL. :rofl: It happens to us all. Have a great evening,
Ahh ok you got it. Great stuff.
Spoke too soon. I can now get into Sremio but not all my addons are there, only 5.
When I look at the same account on my laptop I have 17 addons. The important addons as in Torrentio and realdebrid not showing on the android Stremio. I will walk away again and come back to it later. LOL. I am so confused right now.
No not really. I can now get into the app. But only 5 of my addons are showing but on my laptop stremio where I add the addons, has 17 addons. Very weird. Maybe I have two accounts under the same email with different passwords?? I will log out of the laptop version, sign in with the password I used for the android box and see what happens. Thanks for your reply.
Usually if you just reboot your device they will sync
I really messed things up LOL. When I installed stremio on the android and signed in (eventually) I typed the email incorrectly by one letter. I think it just accepted what I yped and opened a new account? I thought it was my account as there were already addons in the Android stremio. But only a few. so…LOL LOL LOL…I am now going to try and delete the “new account” and sign in again with my CORRECT stremio email/password but I think I have now messed that up and am back to that damn facebook login. anyhoo… off to shut it down and start again.
No luck. I cannot get past the facebook login. Crazy. Will give it all another shot tomorrow when my head is clear again. Hopefully, Thanks again.
You said…Usually if you just reboot your device they will sync. Yes I agree. That is always what has happened in the past when I have installed Stremio on a new device. Oh dear. :grimacing:
Hello Miki, Well it is a new day. I entered the url with the code this morning. The Facebook login page showed for a few seconds then, a caption saying successful. It worked the way it is supposed. Must have been a glitch or ???yesterday with that Facebook login. So annoying when things do not work the way they are supposed to as I tend to not give up and end up uninstalling, re-installing, making crazy changes to Facebook etc etc. Thanks again for replying.
