Stremio downloading torrents
How do you download Terrentio on Stremio? Thanks for any help :slight_smile:
https://torrentio.strem.fun/configure
Please do a search as this is highly talked about.
Tried that did not work.
what to put in the boxes, and search for it in search in stremio?
It works, it’s user error here. Login to stremio go to community addons and install torrrento. Please do a search.
Of course it is user error that is why i am asking for help.
Maybe i am blind or have the wrong version of Stremio but i do not see the addon for Torrentio in the list.
Change it to community addons.
Thanks, i did but will try again after downloading the app.
Are you planning to use Real Debrid with Stremio?
I sent you a pm. If that doesn’t work, pm me back.
You need to click on the gear icon and add RD. It can be a bit of a pain, but worth it in the end. Stremio doesn’t simplify the process.
Unhelpful reply. Torrentio is no longer included in community addons. You have to use the link by Miki posted above
I just checked on my end and Torrentio shows up for me. Try typing in Torretion in the search box.
Troy had a great tutorial on how to install Torrentio in Stremio on z Firestick. The key was the sequencing. 1st, download the Stremio app. After download, do nothing with the app. Do not try to configure or set up as a user. Then using the Silk browser, open Torrentio and fill in the details per the tutorial. That will cause Stremio to open and complete the Stremio set up. Then check the list of addons in Stremio. Torrentio was at the bottom of my list.
For those having difficulty finding or loading addons in stremio this link will help. Simply open it and then notice the buttons with category names. So click on say “movies” and scroll down and all addons needed or available for that category will be displayed. Now I have Stremio loaded on my phone and load all the stuff I need there and it’s automatically added or changed for all devices where I am logged into Stremio. This is an update that is new since Troy’s tutorial.
