I was watching a stream until about an hour ago. Then suddenly it stopped. Since then, i cannot get anything from stremio to play, either on my set top box, my mac or my Samsung phone.
All i get when clicking on a stream, is the movie/ series title flashing on the screen.
I have tried with and without a vpn, plus uninstalling and installing other versions from my backups.
Rebooted everything, including router. Internet speeds are normal at 956mbps download and upload over 270.
My iptv and other internet reliant apps are working fine.
I got my notification from Stremio and a link. I have the playstore and auto updates off. I think the suggestion they give for a device is the best one as for devices like phones it’s a touchscreen device, and for boxs it is a remote. The joy with Stremio is you can always delete and reinstall, then log back in and your entire config is applied without any further input from you. Glitches can happen as well as transfer corruption. gl2u.
Have Fun and STREAM ON!!!
If I remember correctly I went on line to stremio and logged in then set up notifications. Don’t quote me on that though. It’ been a long long time since I first set that all up.
I’ll be firing up Stremio in a bit to watch a series and will check it out for ya Dak. I was watching Ocean reefs this aft without issue, but it does seem like we’ve lost a couple more sources.
Ok @Dak7385 I just tested both series and they are playing fine for me. Not sure what else for you to try. Have you tried different server locations in your VPN?
