Yesterday I was watching S4 of The Morning Show, with all seasons and episodes to choose from. Today all seasons disappeared? When I try to open the show on Stremio it says Comet/RD loading. I tried a different location in SS, I rebooted, I cleared caches. Why would a series that was functioning normally all week, suddenly disapear?
This happened once before, as if something reached into my library and took away all the links to a show. I fixed it by adding more addons via Stremio on my laptop–which fixed it on my PCL. But I don’t know how to fix it now. Before the links disappeared, I had links from Comet, torrentio, RD just many, many to choose from. I pay for RD and premiumize.
deleted and downloaded TMS again and S1 totally loaded, but the menu buttons don’t work as in, it doesn’t tell you what episode is playing, nor how many episodes there are and S2-4 completely missing. checked a couple of other shows, they seem fine.
***** ok, further research made me think that perhaps RD or some other debrid server was down. and now I see everything has just magically returned??? all is working now.
something simlar happened to me a few weeks back… all my shows I usually watch at bedtime just disappeaed….. So thinking quickly I turned off the tv and turned on the radio…that lucky for me was working…. next night Stremio was all back… amazing
This is the Comet addon. Mine stopped scraping and showing sources as well. I waited for a few hours and seems it may have been a maintenance issue. They’re famous for not sending out a notice, they just go ahead and do it, then ignore the complaints. Good addon though.
So good to know. I thought I was losing my mind. Now anyone else having this problem, which it sounds like will happen to many, and which happened to me one other time, can search for this post and know to just give it a little time.
We have been having issues with Stremio lately as well. I have discovered though that now that I have that famous $2 IPTV (?) service hooked up to Tivimate I am finding all kinds of things I thought were only available on my Stremio. It also seems to get them on my screen faster.
I only use Stremio for what it really was designed for, Movies and series. I update Stremio every time one comes out and other than the odd short term problems with an addon it’s never failed me.
Something is going on with Stremio,my Torrentio (v0.0.15) TB is not showing up on all 3 boxes, I have it in my addons and my key from Torbox installed, It was working good but now over the last 2 weeks nothing comes in, not even showing up on my search. any suggestions how to fix this
Miki I also have Comet & just added Duck Stream as per Troys guide 2 weeks ago, all the links come up but do not look like the other addon, but they all work good.Just funny that Torrentio stopped working, it does not even show up on the results when searching.
So I did a little tweaking around on my LAPTOP (Linux mint) and got all the links for Torrentio coming in, but they are not coming in on my other 3 android tv boxes, Do I need to sync my stremio on my latop ? if so how does one do this?
Great thanks Miki, I went on my pc now and logged into my Stremio account and deleted all my history logins (not sure the correct name for this) this logged me out of all my accounts, when I logged back in on my Ugoos AM9, everything is now working as it was before., One addon Comet-ELFHOSTED TB give me on all links “Empty results format configeration” so I have something wrong in my setup for this one addon? when I set this up I just entered in my TB Key, do I need to change other setting? Miki, your works correct?
On a related note (perhaps), my Stremio installs have recently lost a couple of addons - Torz and AIO - they just disappeared overnight! Anybody else experienced this?
I have found a few times that I have to go to the stremio bootstraper and just past a new api token from real debrid and hit load addons preset and then sync to stremio then all is fine.Not sure why stremio gets out of sync with the addons.
