Stremio Apk Versions
@Miki
Hi. On a recent post you solved the issue of Stremio not updating episodes etc. You also suggested visiting a site Stremio - Freedom to Stream
Can you tell me what the difference is from Android Apk version 1.5.8 and the same version with Arm 64, which appears to be the recommended one on the link you provided.
Do the different versions work differently on Android OS versions and Android TV devices.
On Troypoints downloader, if i recall correctly, it showed Apk 1.5.8 Arm Apk as recommended. But on your link it shows Arm 64 apk 1.5.8
as recommemded.
I just need clarification for my learning and to ensure i have reinstalled the correct version.
Many thanks
Those are just hardware specs incase you have a box thatbdoesnt support 64 bit. I wouldnt worry about these specs as lomg as you download the android version once you install it will tell you if its not compatible.
This has no bearing on performance unless you use trakt which is not needed.
Get the latest version works perfectly. The play store with have the android version. If on pc you need windows or mac depending on what you run.
@TP-Dracoo Very many thanks. Much appreciated.
Just one question: why is trakt not needed?
Thank you.
When you go to the site I posted, that is their main download page. It will automatically hilite the correct version for the device you used to go to the download page. So if on a stick it hilites the proper one for it, same goes for computers, phones, tabs etc. Just use the device you want to install it on to go to the downloads page.
@Miki Excellent. Fully understand now. Many thanks.
Regards
Stremio uses its own method when you save to library.
