Anyone using Stremio Android TV Version 1.5.7
If so are you having any issues?
No, not at all really. Working just fine.
I will know shortly, just checked and I was on 1.5.6, so updating and will check
nope, all seems well
also noticed stremio for android is at 1.5.8, android tv is still at 1.5.7
Curious as to which player you are using?
I have 1.5.8 on my tablet and 1.5.7 on my nvidea shield. If your box is actual android tv you should have 1.5.7
Updated my FireTV to 1.5.8 . Stremio has a list of changes if you need it.
Also using 1.5.8 on Z11 Pro Max.
I have V. 1.5.7 and the only thing that seems weird is I have to do all my addons on my laptop and then sync them. Also, there doesn’t seem to be a lot of options in settings.
Other than that, everything plays as normal, and I get the usual number of links.
