Stremio Addon Question
Is it possible to delete all the embedded addons when selecting a source. I have about a dozen or so addons that I do not want or will use. I do not see them appearing in the install/uninstall options when searching addons. I have to scroll down the list every time when I want to get to my addons that I selected. I would like to get rid of these seemingly embedded addons if possible.
Most likely a Miki question but my take is since stremio is basically web based that would be NO. You can remove the ones you dont want but not remove from the web based settings… er I think :joy:
Which addons are these?. You can go into “Addons” and then on the right choose one of three categories. Some are official and I don’t think they can be uninstalled. Any that can be will have install/uninstall bar below that addon. You can’t uninstall “official” addons.
These are addons I believe are embedded in the app? These addons are from major companies that want paid subscription, or the purchase the rental. These always appear ahead of the addons that I added myself.
I don’t know if these addons installed with torrentio or not.
No, you cant remove them becuase stremio is a legitimate app that uses paid Sources.
Ok, thanks for the info. Sent Miki a screenshot of what I was talking about. I kinda figured that was the case. besides, other than just being a little annoying. They do not appear on every program I select.
Thanks again…
If its the ones im thinking off like apple and all that pretty sure the official stuff cant be removed.
Yup, that is one of the many.
