Streams Not Available
I have followed Troy’s instructions and downloaded KODI and then Fen and Crew. When I try to get a movie, all the Real Debrid links appear but every time I click on one, I keep getting the message “No Stream Available”. I deleted KODI and have reinstalled them but am getting the same problem. I am 77 and would appreciate some jargon free help. Many thanks in advance.
I’m assuming if the RD links are showing that you’re on the right path :rofl: maybe try to revoke the RD authorization and then re-authourize it. Good luck :crossed_fingers:
Thank you so much for taking the time to reply Papa S. I read a post that Troy put out a couple oy years ago. I followed his advice but nothing improved. However he suggested it might be a problem with the KODI apps so he suggested trying other apps. I therefore installed 3 apks and they work so the problem seems to have been solved. I really appreciated your advice. Take care.
Nearly every time if Real Debrid links are showing in your results but they won’t play then it means your subscription has expired. Having your account linked allows the scrapers to run, but the links won’t play without an active subscription.
That’s exactly what had happened. DOH!!! Thanks Jayhawks659. [quote=“Jayhawks659, post:4, topic:94360, full:true”]
[/quote]
I am sure that has happened to a lot of us. It has definitely happened to me!
Absolutely. Thanks Brianh76.
On the new Firestick 4K Max, one can load Kodi, but it doesn’t show up in Unknown Apps (under Developer Options), so you can’t install an app like Crew, has anyone found a work around for this problem?
