Storage permission on Downloader
Damn sorry I didn’t mean to send the 1.4.5. Here is the 1.4.4 the 1.4.5 is for GoogleAndroidTV
https://www.apkmirror.com/apk/aftvnews-com/downloader-by-aftvnews-android-tv/downloader-by-aftvnews-android-tv-1-4-4-release/downloader-by-aftvnews-android-tv-1-4-4-android-apk-download/
You did it! It worked! Thank you so much
So sorry I took so long. No excuse but I’ve been very busy with getting ready to move and sometimes hurry a little to much. Glad you got it.
No apologies needed! Have a safe move!!
Ok,
    I DOWNLOADED FLIX VISION AND THEN TRIED TO DOWNLOAD MX PLAYER BUT KEEP GETTING ERROR MESSAGE THEN I GOT THE SAME MESSAGE ON THE BPLAYER😞 PLEASE HELP!!
You can download MX from the Play Store.
MX Player Pro - Apps on Google Play
thanks, but that wasnt my issue, i belie e it was someone else in this post. i had a downloader issue but was solved thx
Samsung has Google play store download it from there
My Downloader problem has been fixed ty
Ok thanks, I got it on my phone now but it’s asking for the URL on Tivimate. I got the premium but I have no playlist! Sorry I swapped over to Tivimate!
What URL? The only URL you put into Tivimate is either an extreme, m3u, m3u8
Ok, I’m going to try and cancel my tivimate order and try something different! Thanks for your help!
**dont give up, had the same issue and figured it out, pm me maybe I can help
Tivimate is by far the best player on the market right now. Sparkle is good and may one day become better than Tivimate, but it isn’t as good at present.
If you are having difficulties in inputting your login info from your provider. Then I along with many others here in the Insider can and are willing to help you.
As far as using an external player in Tivimate. It’s as simple as downloading the player of choice (MX Pro) and then directing Tivimate to use that player in settings. There are several ways to access your external players you wish to use. I have two external players (VLC and MX Pro). I rarely use these players because the Tivimate built-in exo-player is good enough in most cases.
As far as inputting an url. Then you have to go to settings>Playlist>Add playlist> choose which format you wish to use to install your URL, i.e., M3U, M3U8, or Extream.
Most times now you provider will most likely use extream codes (see attachment)
The URL will start with http:// or https://
Then just type the url in the appropriate space and then enter in your UN and PW.
MAKE SURE YOU TYPE IN TH URL, UN, and PW EXACTLY AS YOUR PROVIDER SENT TO YOU!
What exactly did you put on your phone? If it’s an Android phone then it should have been the Tivimate Companion app that you use to Purchase a Premium License to use. I bought the lifetime sub. They will then send you an email with confirmation of payment or a transaction number to verify your account. You then install Tivimate on your streaming device and use the e:mail and password you used when you purchased it. I highly recommend you use the search and read, read, read. The topics, questions, and answers are literally posted everywhere.
Search Is Your Friend...!
]hey Miki i get what youre saying u helped me a ton with i believe free playlists because I got scammed if you remember, now I can learn how to get a sub as you call it
type or paste code here
