Stock Android Tamed
This is stock android Ugoos AM8, no certifications needed. Most any stock box can achieve this without google or amazons blessing. I placed this in iptv services, cause I wasnt sure :joy:
Stock Android Tamed
Nice :+1:
Is this shot off your new AM8 you got a few months back, Ron? If so, it’s pretty dang slick! :sunglasses::call_me_hand:
Yeppers, thats my ugoos am8…running very smooth.
I assume it would be the same as the Ut8 Pro UI ?
The UT8 is a rockchip and the AM8 is amlogic, both ugoos
I see, but operate basically the same?
yea pretty much. I believe both come with Launcher-3 and ULauncher pre installed. Both come ready to root if needed. I prefer the Projectiviy launcher that you see in the vid. On my ut8 I prefer launcher-3 but thats for gaming.
Always thinking about ease of operation for the wife. She has only used Fire os. Personally it looks very clean and easy. Thank you for your invaluable insight!
By the way if your looking at Ugoos…imho THIS is the best bang for your buck.
It’s amlogic X905, 4gb ram and 64gb storage.
Indeed, the specs are top notch. The logical choice, just wish they were a little cheaper. But that’s just me. TY
reason I like Ugoos is I trust it to be free of malware. As they sell products on amazon and Walmart websites I dont think they wouild jeopardize that ability…but not a certain by no means.
Yes I agree. Think there solid streamers!
Does this streamer ever send out updates? I see it is only on Android 11
They do but rarely. I still think android 9 is the best. Newer does not mean better.
I’m a little confused. “Stock Android” I have a MECOOL does this mean there is a way to replace the android system installed installed on the MECOOL with a generic version.
Cheers
Mecool are stock unless its one of the few thats certified like the km2 etc. The video above is stock android, just “tamed” down with another launcher and some tweaks. however even the km2 can look like that…or most any box with a little work.
What was the app between Tivimate and Philo?
That is ChannelsDVR. A paid app I keep saying im gona cancel but I use it more than most.
I got channels DVR to download onto my shield pro, however once I got about 20 channels set up on it and got to the recording aspect it wasn’t what I was looking for. The Emby app you have is it working on its own or is it going through xteve?
