Does anyone know how to remove a Key in STB Emulator Pro on the Firestick. I made the mistake of using the fast forward button on the remote to set up the coloured button for the search feature and now I want to remove it. All of the info I found on the web suggests that you highlight the key you want to remove and then hold down the select button and a delete option window pops up. Unfortunately nothing pops up when I try this. Any help would be appreciated.
