Sportsfire problems
Sports fire is currently not working. Tried it with & without a VPN
Sportsfire is working for me.
I tested it on an device that already has it and I downloaded onto a device that didnt have it. I used @pirate77 downloader code and it worked without issue.
I had my VPN on and my Playstore Play Protect turned off.
Uninstalled the app and then used that code & its working. Thank you
I have just deleted sportsfire and reinstalled it using Pirate 77 downloader code with the surfshark vpn off and it works fine. When I turn surfshark vpn back on I get an error code 251 “unable to connect”. I an baffled. I would add that I am using a firestick 4k
Not sure about Surfshark but check the settings you may have to allow the app
Try streamfireapp.tv, it’s a sports fire tv clone
Thank you, this works well with surfshark.
Happy first day of fall and Happy Anniversary @ElmerFudd :tada:
