Sportsfire Not installing on Galaxy Tab A
I recently installed Sportsfire on one of my many firesticks. No problem. I dug out my old Samsung Galaxy Tab A and tried to do the same. When I downloaded the app via downloader it would not install. I then went on FileHippo and downloaded it again. Tis time it attempted to install but gave a “failed to install” notice. I checked in settings and made sure that under install unknow apps it was allowed. Same thing. I am running Norton 360 but it has not generated any error messages. any advice?
The app is only compatible in FS and Android TV devices. That is directly from their Telegram page.
I know it says Streamfire but it is taken from the Sportsfire Telegram. My assumption it they both have the same compatibility.
Thank you for the quick response. I have never tried installing it on anything other than a fire stick or cube. And I agree. Akums razor would suggest that your assumption is correct.
