Sportsfire download help to put on FireTV
Troy had a download link & info for Sportsfire. I had it on previous tv but now want it on current tv. It was really easy to do with his instructions. Anyone have that info for me?
here is a link sportsfire.tv or downloader 813764 or click on search for instructions or troypoint link How to Install SportsFire V2.0.3 on Firestick & Android TV (troypoint.com)
Search Is Your Friend...!
i need that gif
Long press on it and then choose download. @Powerfader made them.
thanks Miki :+1:
TP Search!
Remember to Search First!
Thanks Miki another great tip.
Can’t get Sportsfire to load. Is there something new for it?
Downloader code 119368
Thanks, I’ll try that new code number. Wish me luck!
It worked!!! Thank you so much! By the way, I also uninstalled Downloader, then installed it again thinking the updated one would work better. And now with this new code, we are a happy NFL family!
your welcome glad to help enjoy
I now bought a Walmart ONN device. The code I got for Sportsfire, does not work with it. Anyone have a new code? Thanks!
Not sure if sportsfire goes on that maybe someone may have the solution I use stick with no problems
Okay, SportsFire wanted an update, Downloader will not let me type into the url line so I can add the 5709452. Help? (since I couldn’t type in, now SportsFire will not open. I uninstalled Downloader, like before, reinstalled it. Again, got to the bar to enter the 7 digit code but I can’t get anything to type in the box.
That sounds like a Downloader issue. You might want to search on TP to help fix it.
Make sure you have the official Downloader byAFTVNEWS and you device is still compatible.
