Split Screen or Picture in Picture for ONN Android TV Box?
Is there some app compatible for ONN boxes that will let you split the screen to run multiple apps at once.. or even better, multiple instances of the same app in a split screen? I would like to maybe launch sportsfire in a window and flixvision in another or even better 2 instances of sportsfire at the same time in 2 windows so i could watch 2 games on the same screen. I know I can do this with iptv software for multiple iptv logins. wanted to make this happen without iptv
Pretty sure the ONN box does not have this functionality. Maybe you can do this on Tivimate on the ONN box with IPTV
Thanks SoloWarrior for the input. The ONN doesn’t have this feature and I know you can do it with Tivimate and other iptv software. I am looking for a 3rd party app. I just thought of another term other than split screen that might trigger some results. Possibly a picture in picture app that would let you run/view 2 or more apps at same time. Older TVs used to have this feature called PIP. I haven’t seen this on a TV in a while though
