Sony Bravia TV with no PCM
Hello,
I have a Sony Bravia model KDL-32BX420.
I tried to add a Vizio soundbar.
I used both an optical cable and analog connection. The reason being, the optical cable allows my firestick to function on the soundbar. I assume because it is HDMI connected to the TV. The analog connection allows my TV roof antennae to partially function, there is no soundbar volume control only a message to turn on PCM or Stereo. The settings on my TV, there is no PCM and under sound Stereo is greyed out.
Is there a workaround available? Is there a converter for coax to HDMI so I can use one of the HDMI in’s on the TV to get local channel reception and have the soundbar function properly.
And more important will it work ? There will be no app, how would I choose channels.
I live in an area where my antennae reception is already digital.
I have researched some and found converters but the coax connection is BNC.
Can a standard RG6 or RG59 fit on a BNC connector?
Please Advise
leahcimj
