Smarters Pro iptv
My Iptv Smarters Pro subscription ran out on Sep 17. didn’t get a renewal email. So I bought a new one so I could get the local channels in my area like I had before. Now no local channels under usa it has one area to chose from 446 channels. Unlike UK channel guide with areas to chose from.The usa guide use to have areas to chose from. Had it before. Tec suport is no help at this time. Anybody know what to do? Thanks Alex
Have you ever tried using an antenna and scanning for local channels on your tv? Unless you’re far away from the city, you should be able to get your local channels this way and they are free as they always have been.
Yes i have a antenna. But sometimes it breaks up with clouds. Then when it rains they are gone. Thanks
The new tablotv tuner is great for locals using your antenna and they throw in a bunch of free internet channels and epg subscription all free other than initial purchase of the box.
