Smarters Pro Installation
Hi all,
I have Smarters Pro installed on Nvidia Shield tube. I have a username and password and an M3url that’s about a gazillion characters long. How am I supposed to get it into the apk?
If you follow the troypoint guide for installing smarters pro, it should be pretty clear…
Copy and paste
Have it and like it pretty cool :v::sunglasses:
Thank you so much! I knew Troypoint would have the right instructions for Smarters Pro but the Shield app will help alot.
I am unable to download iptv smarters using Troy’s tool box on Downloader.
Get error message “webpage not available…connection refused”
Any ideas of what’s happening?
Thanks
most likely unknown sources is not enabled
Thanks, but I am able to download other apps from Troy’s toolbox. Needs to be something else.
I just downloaded it. HERE it is if you want to dl.
Very kind indeed. I am trying to install Smarters Pro on Google TV with Onn
All, apologies for keeping the issue open about the error message I get when trying to download Iptv smarters pro using Downloader from Troy’s tool box (using Onn). I am following the instructions on the topic as suggested, but after typing Troy’s tool box (TTb) code in Downloader and clicking on Iptv smarters pro to download, I get the error message indicated on my first post. I am able to download other apps from the TTb using Downloader, which indicates to me is not a settings issue.
Can someone from Troy’s staff please see if there is a technical issue preventing the download?
Thanks.
Absolutely no issues here. Downloads to droid phone, pixel tab and Shield Pro.
troypoint. com/tb
Enter the above in the downloader browser. Remove the space before com though.
On my 4K onn box I just went in to downloader, Troy point toolbox, and downloaded, IPTV smarter pro. It worked fine. And I just did a test on my 4k onn. I downloaded the TV BRO app from the toolbox. Open Troy point toolbox with TVBRO and download IPTVsmarters pro. Try that. It did work for me. Good luck.
Devon I had that problem as well a while back. I turned of Surfshark and it loaded. I hope that works for you if you are still having problems with it.
I need to add that once loaded I turned Surfshark back on and had no problem setting up Smarters.
thanks a bunch, I’ll try that.
Thanks so much for providing ideas on how to go about it. I think I’ll try firs changing Surfshark location or turn it off while trying to download and see if that does the trick. If not, I’ll try, as you suggested, with TV BRO,
Thanks for checking there are no issues on your end. I have a few ideas from other patrons, so I’ll try those.
