Smart youtube tv and S tube
I’ve restarted my shield pro, uninstalled and reinstalled these two apps. Smart now shows ads.
S tube hangs on ‘User code is loading’, so it doesn’t work at all.
Thoughts?
Thoughts and prayers?
Not sure talking about the same tube here but I also have the nvidea and smart tube installed and when I checked it showed update avail, I installed update and working fine
Are you using smarttube next ? From what I’ve read the others are not being maintained and a lot of people are getting similar issues. If you’re not I’d suggest installing smarttube next. See if that fixes ur issue. Hope that helps.
@rkujay
As @Bam you need to use smarttube next.
