I have set up the Xanax build . The links are very low. I am using real debrid. Is there any way to speed up the process? Thanks
I have deleted Kodi all together, Too Slow.
@mmusolf Look at Troypoint’s Supercharge guide. I’m assuming you use a Fire TV/Stick since you didn’t mention what you were using. Beside real-debrid there are other tweaks you can do that will improve speed.
Will check the Supercharge guide out. Thanks
Hi , I’ve had real issues with the Xanax build I think since an update I’ve deleted and reloaded it but without success. I’ve tried it on several devices Firestick,fire tv,Mecool m8s Pro l and my 256gb shield with no difference to performance it just drags its heels even on my shield so I’ve binned it and using the dream4ever raven build which works.
Same here with xanax build. Anyone have any suggestions.
Great move. If it doesn’t work for you, move on…
