Skystream max | android tv
Greetings,
anyone purchased this device ? if so how do you like it ?
nothing special about the box, its run of the mill standard. Beware tho of all the free claims. The box itself has none of that. You will have to go get and (most likely) pay for that.
Pretty sure you asked this already.
Yeah Sorry the topic was close,so I just figured on new topic
I wouldn’t buy any Skystream product. They are simply putting their logos on cheap Android Boxes that sell for $50. The one they used to use was the X96 Pro…stay away.
ok I won’t get it…i’ll stick with the KM2
