Skeleton build not downloading
So trying to reinstall my Skeleton and Homelander builds. Problem is something about dependencies not being met and not available. Never run into these before. Done some searching but don’t address the issue. Running Kodi and Troy’s fork, both up to date. Just point me in the right direction. Thanks
Got it now but I can’t find the Homelander build in the Crew repo. Is it gone or ?
It doesn’t show in the Crew repo, so am I looking in the wrong place? I downloaded the Skeleton build and it works well. If for some reason Homelander build it’s available what other Movies/TV build would you recommend? I looked at Crewnique, but waaay too busy. I had to rebuild from scratch to get anything to work. Thanks
Got everything I need. Just looking in the wrong place. Thanks
Good talk. Glad we could help lol
