Originally published at: https://troypoint.com/simply-artic-kodi-build/
In this step-by-step guide, we provide installation instructions and details for the Simply Artic Build on Kodi. A fabulous new streaming option, Simply Artic comes from the Diggz Repository which features some of the most popular build options available today including Diggz Xenon. Users will find nearly anything they are looking for and this includes…
I tested this build already. Pretty nice. Needed to get used to the navigation on different skin than Xonfluence. Haven’t been able to test everything but it seems to work well.
Just note if you set up trakt, your Next Episodes are a click down from Recently Watched TV. Its the only section that has a click down menu.
But overall it seems like a good build for anyone looking for a different layout.
I am trying load the diggz build and it says it is unable to connect error
Try to turn off your vpn. Sometimes that gives the error. Not sure why its only sometimes.
Just tested and mine was working witg vpn on
Sorry just to make sure…
You were able to download and install the Chef Omega Wizard but could not download a build?
If you couldnt download the wizard your url may be wrong.
I had to disable surfshark to install.
When I got to the chef omega step and clicked ok to install, I get message “the dependency on script.modules.version 2.19.1 could not be satisfied”
What should I do?
Not sure about the actual error message but i just tried to install just now and it was very slow. I gave up and canceled.
It could be their server is very busy or they are working on something on the wizard/build.
Give some time and hopefully it returns to normal soon.
I did not see that error message when i tried to install.
See if this helps at all. I didn’t read it but it may be a solution for you.
thanks. I will wait and try later. a few of the dependency fixes mention kodi issues.
this is a new install of the omega kodi 21. this box has not had any kodi on it before. just stremio.
Since you have time, I’d delete and reinstall your kodi 21 again just in case something happened when it downloaded.
Couldnt hurt.
it worked after waiting a few hours. Thanks.
Happened to me too bruv.
On two devices FS 4K max and Shield tv tube, with a gigabit connection, took about 10 mins to download on both. it does 1mb about every 3 secs of 249 mb
I stuck with the d/l eventually after canceling many times.
Just installed simply arctic build on troypoint fork i am having trouble finding and enabling the favourites function
Sorry. I see this was from a few days ago.
If you are still looking for Favorites in this build go to Explore and press to the left. Your kodi favorites is the top choice.
The skin for this build is new to me as well. Navigating takes some time to get used to. Pressing to the left or pressing the category name brings you to different places.
Any other questions let me know. I prefer the Xonfluence skin with diggz but like testing others as well.
