Seren not working
Ok ty I will do that
I am having trouble getting seren installed on my firestick. Keep getting an error message. Real debrid and trakt installed and there’s no option to access my tract collection. There’s 2 versions available and neither work. Any help appreciated.
This one works
I told people that on here two months ago, I was probably the one that originally posted it
I’ve used it ever since, no problems :blush: Thanks
The movie database player is in there too. You’re welcome.
Thank you very much. Gonna try it.
No sense in asking elsewhere so here goes
I have Seren set to auto update do I need to do anything else?
Thanks in advance
Not sure which version you’re on or what repo you got it from. If you’re looking for basic setup for Seren to work I’ll leave a link below. You can keep it on auto update but the developer hasn’t put one out in a while.
So, Seren (in the Nixgates repo) has not officially declared compatibility with Kodi 21 Omega. But then I saw in the Diggz repo (when I was installing theTVApp), there was a Seren Omega. I haven’t installed that one as, other than the initial error message, my Seren works fine on Kodi 21. What is the difference between the two repo Serens other than Omega compatibility for the newer (Diggz) one?
As far as I know there the same, just the Omega one has something changed in the script so it doesn’t pop up the error message. :person_shrugging:
Hi all,
I’m using Kodi 21 and my Seren Addon is not working. After selecting the source it just pops up error message ā€œFailed to resolve a playable file, would you like to manually try select the file?ā€ If I choose Yes it pops up file selection but blank with no files to select. If choose No then nothing happens no show is being played. Can anyone advise on this?
Im using Kodi Matrix and worked fine till about 15min. ago and get the same error as the above post?? Any ideas??
Not sure but possible rd problems again :confused:
Sounds very possible
Says No playable sources on all my addons.
Same here l, non of my rd add ons are working
For some reason today, neither Seren or Umbrella will find any playable links. Has anyone else hadthis problem?
