I’ve used Seren with no problems and now it won’t accept Real-debrid authorization kodi flags a notice that authorization has been sucessful but when you go back to Seren it want you to authorize real-debrid
Ive been having problems with Seren on both of my devices. It gives be a prompt saying there’s a problem and to check error log. I can’t be bothered so I just use one of the many addons I have
Mines been glitchy for months, have to switch versions to clear it up. Takes only a second but still annoying. But no problems with RD.
Yeah Pirate, it took me awhile to not spend time & experience frustration troubleshooting an addon when there are so many options that do the job just as well.
My $0.02, I really liked Seren until it became troublesome. Then I moved on. It’s easier to install another addon.
I’ve had similar problems but t I can not under stand error log
You’re supposed to forward the error log to the developer of the addon
Thank you so very much
