Seren error after I install from troy point
seren error when installing add on
Not a lot of info to go on here. When did you get this error? What were you doing? On what device? What Kodi? Many more details are needed.
I get a message when starting kodi, says seren error, I tried to check it out but couldn’t figure out how to solve it. It might effect the addon in some way, this I don’t know, but it seems to work fine like it is.
As far as I know, that error message won’t affect how it works but if it bothers you, the one from Hootys repo has been coded properly for Kodi 21 so the error doesn’t show.
Same problem but if I clear cache every time it solves the problem
https://goldenfreddy0703.github.io/repository.hooty Just Type that repository in and that Seren For omega and if you’re trying to use this on Nexus, it won’t work because it’s a different version. This version is for omega only.
Just look him up on GitHub
thanks for your comments
