Seren has been my Go to Addon For quite a while now as it works so well with real debrid. Recently though it is not performing well ,buffering,foreign language videos And some other problems have kept me from using it and unfortunately it gives you the video to play, you cannot select from A group, At least to my knowledge. Anyone else been having problems with Seren, And am I doing anything wrong on my end?thanks in advance
I used the Seren addon just last night to watch movies without any issue.
As the above mentioned I also been using this on and off for years without that issue. As it’s a premium service that syncs with real debird that kind of problem is something that occurs not often.
The a4k scraper (open scraper project) is pretty good.
Is this happening on a particular show or movie? Feel free to pm it so I can test.
Pm those shows you can’t mention them. I deleted the comment.
If I understand correctly, one of your issues is that Seren is auto playing the source and not letting you select the source you want to stream. If that is the case, go to Tools, Open Settings Menu, Playback. You will see Movie and Episode Play Style and this should be Source Select and not Auto Play. Press OK on the right side column and I believe this should enable you to choose the source you want to view.
Hope this works for you.
I have a 4k Max with Seren 2.1.9 installed in Matrix 19.3, and I am not having any issues finding sources or playing them. With RD integrated into seren I found 33 cached torrents for one movie alone. Now I only watch up to 1080 p and so there may be more but I don’t do 4K. Not sure what to tell ya.
Make sure your real debrid hasn’t ran out of time. I’m also not having issues with seren.
Great info,thank you
