Seren Kodi Addon Installation & Setup Guide for 2023 (troypoint.com)
…and also the provider packages. Make sure those are properly installed.
Yep have it all configured. Works fine until I click out of it and later go back to it. That’s when I get the Error message. Got me stumped lol
Seren is the only add-on you use that acts this way?
Found an in depth guide online, gonna try this tomorrow.
Yeah all my other apps work fine.
These are the exact steps in Troy’s article. They likely copied his material.
I had the same issue with Seren several months ago, uninstalled/reinstalled reauthorized everything and still got error so I just uninstalled it. I use the Crew Wizard for maintenance.
Oh okay my apologies, guess I didn’t read into it enough my bad.
It’s all good, it has a few extra instructions below about settings, but the Seren setup is exactly the same. Unfortunately, lots of people copy Troy’s work because he is the man.
Yeah I go to Troy for all my needs and questions, great guy for sure!
Gotta be ah reason. But appreciate all you people who try to help, thank you!
Good information I need a refresh thanks ![]()
I am currently having an issue with Seren. I run the Diggs Xenon build and have Seren installed and use Real Debrid. Its always worked perfectly for me. I use Seren a lot for searching for old TV shows and it seems to be the best add on for that. But lately every show I search for it says Seren error. I tried uninstalling it, reinstalling, and re authorizing RD, but still is having issues. I can’t see the particular error as I’m not sure where to view that. I guess that might be a starting point. Anyone else had this issue?
I have not been able to use Seren since RD had their hiccup back in Nov. I’ve kinda seen or read there is a work around but it didn’t come from this forum so I didn’t try it.
Yeah it seems to be an issue with TV shows only. I downloaded the addon in my xenon plus build. I was able to play movies with RD and Premiumize. But when i try to play a tv show i get an error message and the screen gets stuck. Have to force close.
I tested with the Umbrella addon and tv shows are working.
Guess they have to fix something.
I think i found a solition for you.
Is the version you have 3.0.62e? That is the version i got when i added it to the build.
Long press over the seren addon and select Information. See what version you have.
Then go to “versions” and select 3.0.62 (without the “e”). It should be under Hootys Repository.
I loaded that version and got tv shows to work again.
And also purged your user’s addon directories of remnants?
