What is the path to “smart Play”?
thx
thx
Go into playback, at the top you should have auto play/source select. I put it on source select. Then scroll down and you’ll see smart play. Turn it off. I also read you’ll only have smartplay if you integrated with trakt. Which I am.
tried it, so far so good!
thx
Grumps
My new installed 20.1 after two days has started to go black when selected unless I force stop in applications. I usually force stop and clear cache after each use but didn’t this time and I got what u were talking about
sad, very sad, I hope somebody figures this out
Just jumping in quickly…I too have had nothing but issues with Seren for quite a while now. Seems every time I re-install and go through the setup, authorize RD/Trakt, the app goes through the sync process and stalls… Not sure what the issue is, but it makes using the app impossible. Not sure why it does that or what is causing it to stall out during the sync process, but it keeps going, even after killing the app from running it starts up again in the background. Just my 2 cents.
Try turning off auto sync in trakt and see what happens
