When I go to look at a TV program it never lets me see the episode. It goes through the engine searches but never completes the download the play button displays at the top of the screen but then it goes back to the home page. With movies sometimes it shows the movie in a foreign language,
Seren has to be setup properly to work but when setup, it is a great addon. Hope this helps.
I’m getting a lot of no providers available on new seasons and episodes. Everything is up to date and/or reauthorized. I use Cinema (still works for me) and Seren.
Maybe the a4kScrapers provider is history? Are there and other providers that work with seren?
Its not, works fine still. Shows may not be uploaded yet.
Thank you
I have done all you suggested. They eventually come up…
