I followed the installation instructions to a “T”, but when I go into Seren, and click discover tv shows, every single category i click has nothing to show. I’ve gone back to the instructions on install, and have done every single thing TROYPOINT says to do. The discover movies tab works though! I can actually watch a movie. Nothing for tv shows though. Help?
You need real debrid… Seren is not free so you didn’t follow instructions.
Keep reading all of the installation. There are several instructions
Jayhawk is correct, a debrid service is pretty much mandatory with all add-ons.
AFA your choice of Seren, it’s a great add-on, but there are extra steps required to incorporate a scrapper. IMO, there are other options which work just as well with less muss and fuss.
Could you let me know which one(s) you’d recommend ? I do have real-debrid and have it active on the tools menu. But I’m totally open to others suggestions . Thank you!
I do have real-debrid.
9Lives has been working Flawlessly for Months
Didnt set it up properly.
My current favorite goto is Fen.
Probably the most popular around here is Crew. Both are currently good choices and don’t require as much setup as Seren.
