I had great luck about three years ago getting an IPTV rec – and, while I did/do still kinda like that service; there’s been enough issues that I have to at least look to see if anything else is out there.
Here are the specific things I’m seeking:
- US/Can channels – stuff that everyone has
- Italian channels
- Robust sports
- Decent/good epg (although I can certainly fill in the gaps)
- Must have a m3u url (not only xtream) - as I then take that url and throw it into m3u4u.com to customize my lineups
- pricing for 2-5 connections
- not a lot of buffering
- Here’s the killer – when I use that m3u4u.com - it creates customized lineups. My current provider – in the past two years – has had server failures where every channel is removed and then every channel is added back - what that does is it decimates the customizations I’ve created in m3u4u.com
- So, I’m looking for a company with at least a year of reliable service – and isn’t prone to that mass deletion/addition (in fact, the company I had before this one removed and added hundreds of channels, basically, daily).
To be fair, I am looking to see if there’s anything better than m3u4u.com (which is free; but is a lot of work to upkeep). I’m also looking for a VPN with split-tunneling (so whatever I use has to work with that, as well).
Currently, I pay about $7/mo for two connections (on a 6-mo plan). Looking for similar.
Hit me with your recommendations ![]()
