SD Maid SE (aka. SD Maid 2) is the successor to SD Maid (SD Maid 1/ SD Maid Legacy)
[APP][8.0+] SD Maid 2/SE - System Cleaner | XDA Forums
https://forum.xda-developers.com/t/app-8-0-sd-maid-2-se-system-cleaner.4568645/
beta here
Has anyone discovered a way to turn on accessibility of SD Maid SE.
Using an Onn device that has recently installed the android TV 14 patch update.
I think that something in the security side of this patch is preventing accessibility to SD Maid SE.
Anytime I try to turn the accessibility feature on in the settings it just immediately turns it right back off.
@Matteos
I had a similar issue where his app using " app cleaner" menu, found items, but couldnt delete them. And accessibilty wouldn’t enable.
I sent him a bug report as requested.
Apparently his app didnt recognise my operating system.
This was his response:
“SD Maid uses the AndroidTV routine which expects each app details to open on a screen with a “Clear cache” button, but in your case it opens on a screen where the “Clear cache” button is one level deeper, behind “Storage and cache”, more like an Android phone instead of a TV device.”
And he provided the fix immediately. This may not apply to you, but its worth contacting him. He is extremely helpful.
His contact details are:
support(at)darken.eu
Hope you get your issue resolved.
Yeah, I figured that app needed an update from the developer to accommodate changes from the recent Android TV 14 patch.
I’ll just patiently wait for the updates to roll out from the app developers.
