SD Maid on Nvidea Shield Pro
I found SD Maid in the Aptoid store or whatever it’s called which I downloaded from the Toolbox. My question is SD safe to run or is their another app recommended instead? Do I even need it to begin with as I already run regularly both of TDUK’s products.
Thanks.
I used to have SD maid on my devices, but no longer do. It is safe, but is redundant if you have available other options.
What would you recommend? :blush:
What is it you want to do using SD Maid?
These are all the utility apps I have installed on my Shield.
ESET Smart TV Security
Virus Total Mobile
TDUK Cache Cleaner
TDUK App Killer
I use the TDUK apps every time I close down my device. The ESET and Virus Total I run on an as needed basis.
No idea just keep things running smoothly. All I have now is TDUK. I’ll check out Virus Total. Thx.
SD Maid is a very good utility. I have the TDUK apps, but in all honesty ilI prefer to use App Killer and SD Maid, cache cleaner isnt a crucial as I always thought it was. Nothing SD maid doesnt already do and more.
SurfShark VPN - Made with Clipchamp
The “Clear Cache Data” in the Shield’s setting is simple and clears more of the cache than the TDUK Cache Cleaner. Not a whole hell of a lot more, but more.
I want to add SD Maid to my Shield Pro. I thought that it was in the Toolbox but it was not. I checked the Play store and got a message that it is not available there either. So I went to Downloader and maybe 4 or 5 links popped up. But, I didn’t feel that I could trust any of the offerings. They all looked a little shady. Any suggestions?
https://www.apkmirror.com/apk/darken/sd-maid/
Thank you, PapaS! Much appreciated, I will give that a shot.
