I had a memory card in my 2019 shield tube and I formatted it a second time and it says it’s corrupted. Tried another and the only response i get is that it is safely ejected but it is still in the slot. Any ideas?
Wipe it using command prompt then format again with Rufus. Then go into the drive properties and somewhere in there you can change the performance settings for either maximum performance or regular. If you want to be able to unplug it without any damage do not change it to maximum performance.
Also I’d leave the shield unplugged for a while for good measure.
Thanks for the advice but you lost me. I can’t figure out how to do that.
Take it out leave overnight un plug shield for the night then put it back in should work it did for me
