I abandoned my long time friend, Real Debrid, when things went sideways. I am glad to see it is still up-and-running albeit less scrapers. I went for Premiumize because of its ease of paying for up to three years in advance. I do, and maybe some of you, have some problems with it bringing me hugely large scrapers with so many of the scrapers in a foreign language and not letting you know in advance in the scraper profile. Is there a way to limit the huge number of large scrapers—I usually use scrapers with 4Gb or less—mostly 2Gb or less. Also, can we eliminate the many languages that are present. In my settings for Cinema, Bee, Film+, I just asked for the English language. Unfortunately, I end up using the free scrapers (Daxi, etc.) a lot of the time. I reached out to Premiumize but they wanted me to download Stremio for using torents—doesn’t make sense to me. Any help would be greatly appreciated.
All of the streams you are access using any Debrid service are torrents.
Debrid services give you access to premium streams instead of the free p2p streams found not using a Debrid service.
The scrapers are the important part of searching indexers where the torrents are hosted.
Lots of torrents have multiple languages within the file.
It’s down to what ever app or Kodi addon and the settings used to play your chosen language of that file first.
I have set Kodi to play English as my chosen language for files.
If the file doesn’t have English it will just play one of the other languages within that file.
You can’t be Stremio for torrents. You choose a movie or show, they present you with a list starting with 4k and going down in resolution. There is always an abundance of 1080 p’s and each torrent shows you how many peers are on it, so best to not choose one with a handful to ensure no buffering. Having said that, there are many times, a stream with fewer peers but they stay connected (You can see exactly how many are on the torrent and connected in the Stremio screen once you start the program) has bee the most stable, ever over and above ones with hundreds. I’m not sure why, this was not true of using and downloading torrents using a client you wanted the most seeders you could get, not just peers who only had partial pieces of the movie, program etc.
That is debatable because you can only use certain scrapers that are available through Stremio addons.
With Kodi you have a bigger selection of scrapers to use and will have more results and also more obscure content older content.
