Samsung smart tv help
how can I add troypoint rapid app installer to a samsung smart tv
Hello @bbenner if you have Google Play Store on it you can simply install Downloader and use that to install. Unfortunately most Samsungs don’t have this. I dont know of any other way unless they are using Android TV as the operating system with Google Play available. I have all Samsungs and most of them I just connect a Firestick as it’s hidden behind the television.
Thank you for your reply. That is what I was thinking that the only way is to use my firestick. I was hoping to not have to put one on this tv though.
@TROYPOINT
Send my files app is very underrated way to send apks and files to your andriod.
Download it on the phone then send to your box/tv.
It’s on the play store. Download it on your Samsung then send from your phone to tv should work.
I would add this to your rapid app just incase I never had to use Downloader with this.
Easy fire tools and apps2Fire are two other options. Easy to use imho.
Our TROYPOINT app does the exact same thing.
My apologies.
Glad it does. I never used it like that as I always had this on my phone.
Can I add Google play to my Samsung smart tv (tu7000)?
Hi! If. You figure it out, please let me know. My tv is a TU700DF and I can’t download a browser, play store. Or anything. I’m about ready to pound my head in the floor
To begin with this is not possible using simple methods. Samsung TVs are Tizen OS and the Playstore is Android OS. Not compatible. So I have a hi end Samsung and have never once used any apps from the main screen. Instead I have a nVidia Shield Pro connected to the TV via an HDMI cable. The TV virtually becomes a monitor, although a very powerful one. You can use whatever device you can afford from a $50 ONN Pro to a top of the line Ugoos. Forget the adding of apps to the Tizen OS. Android all the way.
