Went thru the steps for setting up a usb external drive. After entering smlist-disks and clicking run I always get an smlist-disks not found error.
What so I need to do here to get this part done?
Try the command adb shell sm list-disks
android - sm list-disks not found - Stack Overflow[quote=“rdfish2e, post:1, topic:54515”]
smlist-disks
[/quote]
The following command works on my Firestick 4k.
sm list-disks
Do you have a space between the m and l?
Tried that and it came with the same error mesaage as the other command
No space. Doesn’t show that in the tutorial but will try it.
rdfish2e any luck with
sm list-disks
