Roku channel install on fire tv stick 4k
I have been trying install Roku Channel on fire stick with no success :disappointed:. Apparently it can be done.Any help would be appreciated thanks.
I saw that on unlinked
Thanks for the reply. Yes I seen that on unlink also, there’s two different ones one for a remote and one for Roku channel. Neither one of them will load up even the picture is all blurry when you load it
ROKU Channel is in the Amazon store (freea0.
Thanks so much for replies​:grinning:. Talking Roku customer service and found out only available in the USA. :disappointed:. Trying to find the series ā€œCovert Affairsā€. Was on prime and they drop it. Had 2 seasons left to watch​:disappointed:. Will keep looking thanks
See if you can get the TeaTV apk. It’s got 5 seasons and looks to have plenty of links for each episode.
Thanks for the info will give it a try DavidšŸ‘
I found 5 seasons + ā€œspecialā€ in Stremio. I went to Season 1 Pilot and found 20 sources from 360 to 1080. I chose an hdtv in Torrentio and it loaded and played perfectly. Good luck.
Thanks will try this one also out town for couple days. Thanks
Hi 1953Ford: Try changing your vpn to a USA server.
Now for my question: I used Troypoint to install ROKU but when I follow the instructions …IE hover over the search and type ROKU. The Roku icon shows in the tutorial but not on my screen??
I tried to get it from unlinked but it said error parsing package. Any answers how to get ROKU channel
Also Unlinked app Just updated with new features… so maybe try it again
I think they must have removed The Roku Channel form the appstore.?
I do not see it in the Amazon store.
I c 4 of’em in unlinked , i hit dwnload on the first 1 & it downlded, but I know nothing aftr that, yur on yor own
hth
Thanks just got back home will give it a try.
Hi from what I have found out from ROKU, is it is not available in
Canada. However I have found the show I wanted to watch on the internet on ROKU . With the fire stick I could go on the internet and pull up the show. Thanks for so many that reached out to me with there help and suggestions. David
Found from ROKU it is unavailable in Canada. I got the app on my TV but everything was so blurry you could not do anything or say anythingThanks
Cool …your show is also on BeeTV… all seasons & eps… no RD needed
Strange. I have a ROKU TV in the basement and picture is great. If that is true we cannot get the roku channel in canada why do they sell ROKU tv’s here.
Searched for it on my Fire HD 10 tablet and couldn’t find it, but there are a ton of Roku Remote apps.
