Return of Fusion
Hi
I am aware Fusion was removed a few years ago, there are a number of sources that state it is operating again under there are 2 url’s.
http://fusion.tvaddons.co
AND
http://fusion.tvaddons.ga
Neither URL source loads
Frank
Hi Miki.
thank you for your reply. I have tried the url on my post. it is not working for me?
have you tried it yourself?
Thanks
Frank
Ah I see the problem. You didn’t get the url right
http://fusion.tvaddons.co/
Have a look at the link I provided and don’t forget to get the url exact even the / is important. Follow the instructions and you’ll be g2g.
thanks Miki, the url http://fusion.tvaddons.co/ is one of the two i posted and will not load, a mystery.
I have deleted kodi and reloaded it and still the url will not load.
the server must be down ?
Regards
Frank
I tested it and the network is down.
