Resetting a KM 2 Plus
Can anyone help resetting a new KM2 plus box there is no reset button try to download file sent from MeCool to USB extracted but cannot get box to open, all I am getting is storage is full on the upper right side not able to get to the home screen.
I too want to reset my KM2 Plus, did you manage to do it?
…via xda…
This works for all Android TV boxes with S905X4 chip.
Method 1:
  1. Power off the device.​
  2. Disconnect power cable.​
  3. Keep pressing reset button while connecting the power cable.​
  4. After a few settings the recovery mode should start.​
Method 2:
  1. Enable developer mode.​
  2. Enable USB debugging.​
  3. Connect the device via USB cable to your pc.​
  4. Download platform-tools (adb) - download link
  5. Open CMD window in folder with adb.exe file.​
  6. Execute “adb devices” to check if Windows recognizes the Android TV box.​
  7. Execute “adb reboot recovey”.​
  8. Device should boot in recovery mode.​
Method 3 - if recovery is broken:
  1. Download link
  2. Format a USB stick to the FAT32 file system .​
  3. Copy the aml_ autoscript and twrp.img files which you just downloaded to the root of the USB drive.​
  4. Power off the device and disconnect power cable.​
  5. Insert the USB stick into the OTG USB port of the device (just try which of the USB ports works).​
  6. Connect power to the device while pressing the “RESET” button for 5-7 seconds.​
  7. TWRP (recovery) should start.​
Source: https://slimboxtv.ru/twrp-vremennoe/
edit>> I would only try method #1 unless you really know what you are doing. imho
The KM2 Plus doesn’t have a reset button, so Method 1 isn’t an option, and the others require a Windows PC and is beyond my capabilities.
I’ve reached out to Mecool to see if they have a solution.
press the power button on the remote on boot. Hold it down the entire boot.
I’m afraid that didn’t do anything.
